Like a hall of mirrors, nanostructures trap photons inside ultrathin solar cells
Post by Cr6 on Tue Nov 21, 2017 1:52 am
Keep in mind:
<b>Like a hall of mirrors, nanostructures trap photons inside ultrathin solar cells</b>
In the quest to make sun power more competitive, researchers are designing ultrathin solar cells that cut material costs. At the same time, they’re keeping these thin cells efficient by sculpting their surfaces with photovoltaic nanostructures that behave like a molecular hall of mirrors.
“We want to make sure light spends more quality time inside a solar cell,” said Mark Brongersma, a professor of materials science and engineering at Stanford and co-author of a review article in Nature Materials.
Brongersma and two Stanford colleagues – associate professor of materials science and engineering Yi Cui and professor of electrical engineering Shanhui Fan – surveyed 109 recent scientific papers from teams around the world.
Their overview revolves around a basic theme: looking at the many different ways researchers are trying to maximize the collisions between photons and electrons in the thinnest possible layers of photovoltaic materials. The goal is to reveal trends and best practices that will help drive developments in the field.
Solar energy can be harvested when photons of light collide with the electrons in a photovoltaic crystal and set them free. As loose electrons move through the crystal, they generate an electrical current.
Yet even as researchers succeed in getting more from less, many hurdles remain, according to Fan, who develops computer models to study how different nanostructures and materials will affect photon-electron interactions.
“There are an infinite number of structures, so it isn’t possible to model them all,” he said, alluding to what he called the “theoretical bottlenecks” that impede scientific understanding of this ethereal realm where light and matter intersect.
“For instance, right now, we really don’t have a way to know when we’ve gotten the most out of our photons,” Fan said.
Today’s solar cells are already thin. They are made up of layers of photovoltaic materials, generally silicon, that average 150 to 300 micrometers, which is roughly the diameter of two to three human hairs.
As engineers continue to shave down those dimensions they have to develop new nanoscale traps and snares to ensure that photons don’t simply whiz through their ultrathin solar cells before the electrical sparks can fly.
Scientists Can Now Switch Between Electrons And Photons in a Single Transistor
Post by Cr6 on Tue Nov 21, 2017 1:56 am
Welcome to the future.
11 MAY 2017
Researchers have developed a new kind of transistor laser that can switch between two stable energy states – electronic and photonic – which could one day enable data transfer 100 times faster than conventional digital devices.
The transistor prototype features what's called bistability – the capability for a single switch to alternate between optical and electrical signal output – and could help lead to the development of light-based computer systems where data is shuttled in between semiconductors by photons instead of simply electrons.
"Building a transistor with electrical and optical bistability into a computer chip will significantly increase processing speeds," says microelectronics engineer Milton Feng from the University of Illinois at Urbana-Champaign, "because the devices can communicate without the interference that occurs when limited to electron-only transistors."
In conventional electronic devices, microchips are made up of billions of tiny switches called transistors, which act as gateways to channel the flow of electrons across an integrated circuit.
The problem with this model – which has worked pretty well for electronic devices for several decades up until now – is that as modern computer processors have become ever faster and more powerful, the number of transistors on them inevitably increases.
This tendency is what's called Moore's Law – the famous prediction by Intel co-founder Gordon Moore that the transistor count on an integrated circuit will double every two years.
Moore's Law has actually held up pretty well since it was first forecast back in the 1960s, but a range of technical issues are currently threatening to derail its continuation – which could put a stop to processors getting faster, if we can't think of new ways to build them.
Chiefly, transistors have gotten so incredibly small now that it's getting harder to physically shrink them any further, and there are also concerns about how energy-efficient electron-based transistors will be if Moore's Law does continue in the future.
Besides those points, since light can travel significantly faster than electrons inside an integrated circuit, moving to photonics-based processors in place of solely electronic devices makes a lot of sense, which is why scientists are busy studying how we can develop light-based computers.
To that end, Feng and fellow researcher Nick Holonyak Jr first developed the concept of the transistor laser back in 2004 – a semiconductor device that incorporates both electrical and optical outputs.
"The fastest way for current to switch in a semiconductor material is for the electrons to jump between bands in the material in a process called tunnelling," Feng explained in 2016.
"Light photons help shuttle the electrons across, a process called intra-cavity photon-assisted tunnelling, making the device much faster."
In their latest research, the same team has now described how the transistor laser can switch between the two signals – a crucial distinction for optical computing, since despite the allure of photonics, the researchers say we will still need to accommodate electrons in future chip designs.
"You cannot remove electronics entirely because you need to plug into a current and convert that into light," says Feng.
"That's the problem with the all-optical computer concept some people talk about. It just is not possible because there is no such thing as an all-optical system."
In the new study, the researchers detail how they've got their bistable switch working at -50 degrees Celsius (-58 degrees Fahrenheit).
The researchers further claim to have actually gotten the device working at room temperature – which is pretty important if we're ever going to use these transistors in actual devices – and will share details on how they accomplished that in an upcoming paper.
As for when we'll see this kind of technology in our smartphones and notebooks, it's still not entirely clear.
